I just got this motor running after sitting for 10+ years. I rebuilt the fuel pump, water pump, and carburetor. I noticed water coming out of a couple spots and in having trouble finding whether it should be discharging there or not. The larger dime sized hole I believe is some sort of exhaust outlet. There's also two pinholes on the port side of the gear case that I'm uncertain what they are for. Other than that the motor runs great. Started up after a couple of cranks. Strong warm water coming out the **** hole with muffs and with pump submerged in bucket of water. Feel free to enlighten me with the vast knowledge of this community
Also, any recommendations on removing dried hard grease from the lube points? Doesn't look like any fun.
