Fowl_obsession
- Jul 5, 2015
- 29
we are moving along on our boat build project. after taking the boat to a mechanic we found that the power pack was bad causing the center cylinder not to fire. i had the starter rebuilt which fired the moror up about 10 times before going bad again. when it did fire, it would only do it while being choked then it would rev really high and cut off. any idea on what could be causing this?
