welcome aboard.
as indicated above, 4 things to turn lefty-loosy (battery clamp connection, starter positive connection, two starter bolt.
however why are you removing your starter, 99.95% of the time if the starter doesnt spin, its a bad connection. make sure you clean every battery cable connection to the point where you can eat off them.
