studioq
- Apr 11, 2014
- 201
I've had this issue now with 3 different fuel tanks. 1998 Johnson 50 SPL carbed - running on mix gas only.
With the old metal, 6-gallon OMC fuel tank - the motor can be started, stopped and restarted without any issue. It has yet to cause any trouble.
When I switch to my reserve tank - a 6-gallon plastic OMC tank and run for a while and then shut off the motor - it is very hard to restart - almost as if the motor has lost prime and can't be primed even if the fuel bulb is pumped. Strange thing is - raw oil is discharged into the water after consecutive attempts to restart. After a while of cranking and pumping the bulb - cranking some more - the engine comes to life once the old metal tank has been put back on.
So I went and bought a new 12 gallon tank that is the new style of EPA approved, vent-less blah, blah, blah - and it comes with its own special hose with a pressure regulator to prevent engine flooding when the new vent-less tank becomes pressurized by heat, etc.
I put this tank on - the hose is a little difficult to prime (get the bulb to firm up) - but then the motor starts and runs for hours without issue. Once you shut the motor off it becomes impossible to get the bulb to prime again and you have to crank forever and it won't start until you put the old metal tank on again. And it does discharge oil during the cranking process - but not after the motor kicks over and begins to burn.
Kind of at a loss with this one..
