Hi. I recently picked up an old 1978 Johnson 25 hp 25R78C
After repairing the pull start I got it to run and it seems to run quite well, Except that when I decelerate a bright orange spark (about an inch long) leaps between the block and the plate (ignition advance?) under the fly wheel that moves (rotates) when you throttle up or down. It makes quite a loud crack and is only a couple of inches from the fuel pump! I have tested the magneto coil, sensor coil, stop circuit, and both ignition coils, with a multimeter for correct continuity and resistance. From what I can tell with my limited experience they seem ok which leads me to think it could be the power pack?
Does anybody have any ideas what would cause this? Any advice would be appreciated.
Cheers Tom
Cheers Tom
