I recently replaced the lower unit on my E15RCOB 85. It runs great, except when I get to the top 1/4 of the throttle. Once I hit a certain speed, the shift lever tries to fall backwards and shift out of forward into neutral. It doesn't shift completely out, but every 10 seconds or so, it goes WHUMP, WHUMP. It feels like I hit two stumps in a row. Then 10 seconds later, it will do it again.
If I use a bungee cord to secure the shifter in the forward position, it will not do this. Then, I can go top speed without any issues. However, as soon as I remove the bungee cord, it starts again.
Is this simply an issue of tightening the shifter lever so it won't try to fall into neutral?
