Lakeside 1
- Jun 16, 2015
- 6
I have had numerous electcronics replaced on this motor. My mechanic finally got it running smoothly. Out on a hot run yesterday. Parked the boat and noticed smoke from under the cowling. Pulled the top off fearing a fire. Further observation, noticed smoke coming from what I know now is the voltage regulator/rectifier? I unplugged the battery and the smoking stopped. I recently had the charging coil and power pack replaced. I have pulled the boat out. I also touched the battery lead to verify and indeed smoke was coming from the voltage area and I noticed a gel substance had leaked onto the motor. Talking about a smell. Finally. Will this smoking regulator when replaced require me to replace the charging coil and power pack again? This adventure started out as a used motor purchase. One may not be connected with the other but the hits just keep on coming. And I have heard already about how a boat is a hole in the ocean to put money into. I have three. Thank you and a quick response would be greatly appreciated because I am getting ready to put this baby in its rack for the winter.
