Evinrude 60HP 1989 Overheat
Two Summers ago my Evinrude 60hp overheat the head gasket was burned and the middle piston smelt a little
Scenario:
Overheat Buzzer not working
Water pump was working well
Engine was peeing strongly
I went to the official Evinrude dealer and they redo the engine:
3 carburettors (Done)
Thermostat (done)
Temperature sensor(done)
Piston (Done)
Water pomp (Done)
Temperature Buzzer( was not changed or did not work)
This summer it overheated again and the head gasket was burned (same place that last time middle cylinder). I was checking all time and the engine was peeing very strongly. Heating Buzzer did not work
Scenario:
Thermostat (done)
Piston (Done)
Water pomp (Done)
- What are the reason why a engine overheat?
- Could be that middle carburetor is not working well and is not feeding the cylinder; therefore, it work dry and burn gasket?
- Could the engine overheat with water going through and coming hot? Could be that I did tubing?
