mark in new jersey
- Sep 7, 2011
- 167
Hey gang!
It's been a very long time since I've posted, so here's a brief catch-up: I got my engine running great! After three...yes, three... carb rebuilds, it turns out that the sintered fuel filter was completely blocked. New filter, and this runs really well.
If you remember my old posts (or, even if you don't!!), I converted this to a pump system, but as I struggled mightily to get this engine to run, I had to "step back" and remove any variables that I had entered into the equation. Thinking that my pump might have been the issue, I dismantled the pump, went back to a pressure tank, etc., etc. As stated, the issue was a bad filter, but I didn't know it then. All I knew was that I had air & spark.....the problem was clearly "fuel". So my troubleshooting required the removal of the pump & plumbing.
That said, I was never 100% happy with the pump I had installed. Someone had recommended...and I bought....a pump that, in retrospect, was way too big. It had a capacity to fuel a much larger engine than this little 15HP, the consequence of which was that it was hard to fit / mount under the cowling, harder still to plumb. I tossed it with no regrets.
Fast forward: I'm thinking about going back to a pump system, but I want the smallest possible pump for this engine, and I'm seeking specific recommendations. I've already tapped (1/8" NPT) the center hole in one of my bypass covers, so I'd like to obtain my "pulse" there. Mounting there would be great, too....if possible.
So: for those of you who have converted a 15012 (or an 013, 014, 015, etc.), what small pumps have you used successfully? I'm looking for specific make & model number....
Thanks much! And, it's good to be back! I'm going to begin building a boat of my own, and I can't wait to get this engine "back in the game"
Mark in New Jersey
Mark in New Jersey
