I have started several threads regarding this motor, according to the previous owner, the motor was submerged in 2003. I do not know what was done then, but I know that it has been in use for several years after that. The motor had not been in use for three years when I bought it.
I have overhauled the carbs, and it has fired. I decided today to have a look behind the intake manifold. I found some very smooth sandy material behind the leaf valves, please see the attached pictures. Is my only choice to take out the powerhead, clean it, and change the piston rings to make this a safe motor?
The compression was from 78 to 95 PSI (cold motor, and before the carbs were overhauled)
