engine will run for 3 mins at 3000 plus RPM and then continuous warning horn goes off,,engine also shudders..throttle down until warning ceases, run it back up to 2500 rpm and it runs ok b ut still has a slight shudder...second engine same year runs A ok and takes most of the load in powering the boat..plugs and wires new, water separators replaced, checked fuel filters and appear ok but told to change as all signs point to filter . Is a Sierra 18-79781 the correct one for this engine?
