airbus320
- Oct 14, 2015
- 20
Greetings,
I recently acquired a new-to-me boat with a 1977 70HP Johnson outboard.
The motor will only start with the warm-up lever at about 50%-75% of its travel (up). Once started it idles, but quickly dies once the warm-up lever is dropped to it's lowest manual position. As you may be aware, the warm-up lever drops to a stop below the lowest manual setting once the motor is shifted into gear. The motor cuts out immediately upon shifting into gear.
I am a licensed aircraft mechanic and have some familiarity with smaller outboard maintenance and repair. However, I have not done any troubleshooting on the issue...yet. The original owner is coming tomorrow to take a look first. He told me that the motor ran great this summer, with no related issues. I also wanted to see if anyone has experienced this issue as well, so I could go to the table with a bit of knowledge.
Hopefully,the attached video will better demonstrate the problem.
Please note:
-The prop spins freely by hand when the control lever is in neutral
-The prop is has resistance in FWD/REV when turned by hand and the flywheel starts to turn. I haven't disconnected the ignition yet, so I didn't move it by hand through a full turn in gear. However, it feels very tight.
Any help or suggestions would be greatly appreciated.
Thank you!
JD
Please note:
Thank you!
JD
