My 1966 Evinrude Big Twin has developed a unique problem. It usually starts up and runs fine
but does so only on the top cylinder. About 1/2-2/3 throttle the other cylinder will suddenly cut in
and the engine opens up and runs fine at high planing speeds.
I believe it is fuel related because I left the bottom spark plug in but pulled the boot and put a
spare plug in to see if there was spark while the engine was running. There is spark. In 2013
I replaced the entire ignition system (used Atom modules instead of points) and have had no
issues with it.
I thought possibly my fuel pump needed replacing so I did that and while the new pump works
great the problem persists.
I'm planning on rebuilding the carb because I am also having an issue fo the engine occasionally
not starting. Draining the fuel from the carb usually enables the engine to fire right up and run
well so I'm assuming the needle/float/seat are suspect.
Could this possibly be a bad leaf valve? Is it possible that one or more of the valves is
failing and not getting fuel into the lower cylinder when the vacuum pressure is low... but it
increases at higher RPMS and everything is fine?
Compression 88/90 on the cylinders which I believe is well in the proper range for this era of outboard.
issues with it.
