Adam Johnson
- Oct 7, 2015
- 2
I have a 2004 Johnson Suzuki) 15 HP 4 Stroke engine (J15TEL4SR) .
I am trying to change the timing belt and adjust the valve clearance.
I purchased the universal Flywheel Puller Kit (378103) and none of the bolts will thread into the holes. The smallest set will barely start but the stop turning so I didn't force them.
In my shop manual they list Flywheel Remover Bolts (5034235) along with the Puller Kit.
Will the smallest set work and I just need to clean the hole or use a wrench to get them started?
Do I need the additional Flywheel Remover Bolts (5034235)?
Can you tell me what size - thread the bolts need to be and is there a better solution than these?
Thank you, Adam
Thank you, Adam
