Okay guys I have searched and tried almost everything I usually take boat out 2-3 times a month well I let it sit 3 weeks in storage took it out for some weekday fishing was a little tough to start but got it fired up take of will not get past 3000 rpms anywhere past 2500 starts bogging and missing changed the plugs on the water did not change pump bulb while running did not change good news is I atlas caught alot of fish Spent all day today working on it Removed carbs cleaned thoroughly ran tip cleaner through all the Jets they had new kits in them about 6 months ago Replaced inline filter and spin on separator Went ahead replaced all fuel line with new bulb I have not checked compression yet but would assume it's good trip before this one ran great wouldn't imagine it'd lose compression sitting Check spark and all wire connections are good 3 months ago I installed new plugs wires 4 coils and cdi box Not sure where to look next it idles great starts good runs the 2500 great but will not take anymore has good power would lift bow and dig boat deep I would think fuel issue but carbs were spotless cleaned with tip cleaned all 6 jets Not sure where to check next any ideas?? 1996 90 hp johnson vro is disabled properly I mix 50:1 and run seafood every 3rd tank I also run premium fuel everytime boat is an 18ft kenner tunnel 1996 model Thank you for reading any help is greatly appreciated trying to save a trip to the shop
