Johnson/Evinrude service manuals talk about removing 1 large bolt above and starboard side of the carb, and 3 bolts OR NUTS to remove the starter bracket. None mention the two smaller bolts in the lower support bracket... and that leads to my question. I removed the three nuts, but the bracket will not clear the studs that are screwed into the engine. The starter hits the case. How does the bracket come off in this situation? Do I remove the studs? If I need to remove the studs... how? Is there anything special I need to know when I put the studs back i.e. thread locker or sealant?
