The 77 85 hp engine had an option for power trim and tilt. It was not the newer style, however. It used a set of dual rams, mounted outside the transom brackets and mounted to a large lift bracket that was bolted to the swivel bracket. It was not the neat-looking arrangement that you see today, but it worked. These units have been NLA for probably 20 years and parts for them are getting hard to come by. You can compare the parts for this trim setup with the newer style which came out first on the 140 hp units in 1977. Check out this factory parts website: epc.brp.com Aftermarket units are also available that will also perform this function. See any dealer and have a look in his Land N Sea marine parts catalog.
