Bought the boat with outboard specified this summer and was able to use it the whole summer. I have always had problems starting but once it starts, i can re-start easily. Now, 3 weeks from the last time I used it, it wont start at all. Tried many things I found on the net like, priming properly, choke for 8-10 seconds, battery is good, disconnected the lanyard switch (black wire with yellow stripe), check my ignition coils, check ohms of wires coming from the stator (under the flywheel) and my readings were good. (brown wire 11ohms, the other bundle of wires with different colors one is white got 450-500 ohms in each). Someone told me I could have a bad power pack which I already ordered. The problem now is i'm not getting any sparks from all plugs. Question is, is there anything that I might have missed after what i have mentioned already?
