I am about to redo the entire fuel setup on my Evinrude 6hp outboard and I have a few questions: The hose on there now is about 5ft long and comes off the tank and coils around on the back floor then goes up to the engine - however I have heard recently that the primer bulb is suppose to be vertical to the engine instead of laying flat. I plan on running from the fuel tank just a couple of feet to the bulb and then another 8" or so to the engine. Is this the correct setup ? or is there a specific reason to have the fuel line this long ? I want to do it correctly especially since I have having some fuel / engine issues (I will post seperately for this issue) and I am trying to trouble shoot right now. Is there a right and wrong way of setting up the fuel tank and hose to the engine ? I also want to put an inline fuel filter in, which is on there now but I cannot find a good one and everything I have read says to use a water seperator ? would that be needed on my small 6hp ? any input would be greatly appreciated. Thank you to all in advance.
