I have recently been upgrading my 1982 4.5 hp evinrude motor but have run into a new problem as the motor will not start. After testing the electrical I found there is no spark in my spark plug. I traced the wires back and have found no electrical all the way back to the magneto. In addition to not starting when you Pull the pull cord, the motor sends an electrical shock that goes through the entire unit and will shock the heck out of you if you were touching the motor. The motor will not start and will not run. I believe something is going on in either the magneto or the ignition coil. I'm not very good with electrical and am wondering if any of you have some ideas on what to look for to fix this problem. I just recently replaced the kill switch mechanism and rebuilt the carburetor. Please help as I would love to get back on the water!
