1976 Johnson 115hp should I replace rings on one the one piston???
cforgan
I am about to tear into this motor to replace the crankcase seal. I did a compression test on this motor and found I had a 10-15% difference between the 4 cylinders. Three of them were very close with 1 of the 4 making the 10-15% difference. From my understanding this is within specs but since I am tearing the power head apart does it make sense to rehone and replace the rings on this one piston? sorry I am new to this and this is my first outboard rebuild so I don't want do anything that will cause further damage.
Thanks in advance for you help
Boat Doctor1
no= seal is easy & if you hone -you will increase the blowby even with new rings!! Not worth it!
Facts----The motor is 40 years old and may have many hrs on it.----------The ring grooves in pistons also wear.-------Look at them under a microscope !--------So installing new rings on an old piston is not considered " good practice " and that o-ring material is easy to get at any BRP dealer / boat shop !
emdsapmgr
No reason to reassemble an overhauled engine with only one new ringset. You could have the other 3 old ringsets fail one or two months later. Replace all 4 at once.
No, no O/S rings like that.-----If I recall those piston rings are way up near the top of the pistons.----A wise man would install 4 new pistons !!
ondarvr
On a motor that old "if" I decided to take it apart because I needed to replace a couple of parts, it would be complete rebuild, I can't see going through all that work and money and still having a 90% old tired motor.
1983 ercoa 21'
that's what I'm a thinking might as well replace all the pistons.
Piston rings are around $32 for each cylinder.---New piston kits with rings are around $105 or so.--Do the math.--But first inspect all the parts after tear down of the powerhead.
Thompsoncustom
If the pistons are all in good shape I would call up someone like wiseco, total seal, etc and give them your specs for the rings and ask if they have any that are a couple thousands over. They probably do and at a better price than most, I also would hone all the cylinders and replace all the rings.
?????---But the WISCO replacement rings only fit WISECO pistons.----WISECO rings will not fit in factory original 1976 pistons !!!!
Thompsoncustom
Not completely true there is some overlap but for the most part yes wiseco rings are for wiseco pistons, I was only using them as a manufacturer example.
emdsapmgr
Factory oversize pistons (with ringsets) come in these sizes: standard, .020 over, .030 over and .040 over. You can mix any of these sizes on one engine. Whatever you decide, you must be sure that all 4 pistons are from the same manufacturer.
