Thompsoncustom
- Aug 22, 2015
- 79
I have a 1990 johnson 20hp that I got as a project engine. It ran but only at high speed, turns out it's missing some of the throttle linkage so that should be a easy fix. I adjusted the carb by hand and started it at just above normal idle and it was backfiring through the exhaust and than would just die at low RPM. I pulled the carb off and cleaned it today and now it idles at what I would say is a normal RPM but it will still backfire and die at low normal idle. When I was in the carb I seen the needle was off to one side and I wasn't sure if this was normal or if this could be the cause of my backfires.
