Out of the hole and WOT like a slug. Compression test all 125+ Spark test 3 good over 3/8 gap. Lower left no spark, but didn't narrow gap as considered 3/8 min.
Have Evinrude Service Manual. Checked ignition coil with ohmmeter. Seems to meet specs and compares to left upper. Also off engine / on bench tested both left and right power packs with ohmmeter They seem to be within specs and are the same. I don't think the high tension lead to spark plug is leaking to ground. Didn't see or hear anything.
Any info. to help solve this one cylinder problem would be much appreciated.
