1970 85 hp johnson ..won't pee .hot light comes on after a little bit ...replaced water impeller still no pee and hot light comes on is there anything else that would cause this ....possibly thermostat sticking ...how can I tell if water is pumping to tell if water pump is function ...and or thermostat without removing the parts ..thanks n advance...
