I am having problems with my motor I prime the motor and it runs fine until float bowl on fuel bracket is empty. The bowl is not refilling. I replaced the cover the float and needle valve in the bowl and also tried two different tanks and two different sets of fuel lines. Still has the same problem any ideas why the bowl wont refill like it is suppose to. Thanks
