These engines are all adjusted different!! Try setting the low speed screw closed & back out 1 & 1/2 turns. Then High speed closed & back out 1/2 turn to 3/4 turn. if it runs - slow- turn low speed in till coughs then back out maybe 1/2 turn. then put in gear run @ fast speed & reset in that needle till coughs or dies- back out till runs good.
