TiredOldJohnson
- May 11, 2015
- 13
Alright everyone I am either doing something wrong or I have a very very stuck flywheel. The motor is a 1957 Johnson 18hp FD-11. I have removed the pull start assembly. I have also removed the nut on the top of the shaft as well as the three screws that are around it. I tried using a flywheel puller and it is on there so good that the bolts were starting to pull the threads out of the flywheel. Does anyone have any other ideas on getting it loose? Did I miss removing a part that is holding it on? I am about to go buy a massive 3 jaw puller and try that but id rather not spend the money if there is an easier way. Any help is much appreciated.
