I bought the engine death with burnout piston. this is 1987 Evinrude V6 175hp # model E175TXCDR J1143976
So I take out part by part, replace sleeve,cut block for new pistons, new bearings, new seals . Every parts replace for new . After rebuild motor from first start running nice. But when I increase rpm and
release carburettor accelerator , close gas and air . Motor holding high rpm until I kill with ignition key. When I start again with release accelerator running on low rpm.
So I thing maybe I need rebuilt carburettors and after rebuilt I have same problem. Then I replace timer base and two ignition power packs. And same problem. The motor has no more old parts to replace. Guys please help me . Any suggestion I will be appreciate you .This is very strange ,from where motor take air to running on high rpm. Though carburettors are close.
This is video with problem.
