gwgautney
- Aug 28, 2013
- 283
Ok boat ran good all day Friday until I got ready to head in. Took off from rig and boat bucked and wouldn't take fuel. I had my friend pump bulb and it took off as and ran fine as long as he pumped the bulb. I bypassed filter to make sure it wasn't clogged filter and no change. Now when I got home and was going to run it it acted like it was locking up. It would turn over a couple times and stop. It did this a few times and then turned over and cranked. It will rev fine on the hose. Checked compression bottom left cylinder was 90 the other ones were 100 to 105. Trying to figure out if I have dropped a cylinder or a head gasket or fuel pump.
