Acheron2010
- Apr 4, 2015
- 11
The pic is the OMC throttle control on a 1987 Wahoo 16.2 with an 1982 Johnson 75. I replaced the entire lower end unit with another, and testing it in my driveway, discover my neutral throttle position is as shown - about 10 o'clock as you look at it.
I see cable adjusters on the side of the engine - can I use these to move the lever to 12 o'clock, or is this the default position for these OMC controllers, or ?
