I bought a 1982 35hp evinrude 7 years ago. Before i could even get it on the water the motor locked up. I then decided to tear down the entire motor to find the problem. It turned out to be the piston rod end cap bolts had come out of the rod. I installed new pistons, rods, bearings and bolts. The motor was then put back together very carefully making sure that I torqued all the bolts to spec. Over the last 5 years the motor has run like a champ until just this last weekend when once again the bolts loosened and locked the motor in the middle of my vacation. What can I do to rid myself of this during the next repair? What is causing it to last 5 years then coming loose? Is there a better way of keeping those bolts from doing this again? Any input is much appreciated.
