RRaulH
- Aug 12, 2015
- 9
I've been trying to find an explanation for my sudden loss of power and consequently a lower rpm at wot. I've been reading a lot of post on here and other forums, but have yet to find a solution or explanation for my problem. I hope some of you might be able to shed some light on my situation. I have a 1984 evinrude 35hp outboard engine mounted on a bracket with a setback of +/- 1 ft this is mounted on a 16 ft cranchi motorboat. I've had this motor for about half a year now and have had no major troubles with it, besides my loss of power in the last 2 weeks. I'm running clean fuel, new spark plugs and have disconnected the choke from the carb which seems faulty since it keeps pumping fuel whether on or off . The motor still starts up on the first try every single time, and seems to run good.
The motor seems to have lost some power and rpm. Before I was getting on plane quite easily with 2 people on board, which now is just doable but topspeed has drastically reduced. I used to be able to get a top speed of around 25mph at wot and now this had dropped to around 20mph with only the driver on board. With an additional person on board the speed is greatly reduced from +/- 23 mph to around 15 mph at wot. I've added a video of the engine running at wot before and after so you can hear and see the difference. Any help would be greatly appreciated.
Additional info:
Boat 16 ft Cranchi
weight 1100 pounds with driver
Outboard 1984 evinrude 35 hp 20"longshaft on 1ft setback
Video: before and after
Additional info:
Boat 16 ft Cranchi
