1977 Johnson 70 remote to tiller conversion?
LAcustoms
Hi looking to convert my 1977 Johnson 70 from remote steer to tiller. I bought a used arm off a newer 75/90, arm bolts on. I need to get a shifter rod for it, will the arm for 04 Etec motor line up with mine? also what do i need to get the throttle cable mounted on the motor?
LAcustoms
if anyone with a tiller can post up some pictures of the throttle/shift side of the motor that would help immensely
