I was heading back to the marina at full throttle when I hit a bit of wake causing the engine to slow down. I was very low on fuel and thought this might be the problem since the throttle would adust on it's own as the boat rocked. I filled up at the gas dock with 91 ethanol free, 50:1 2 stroke oil, and a capful of sta-bil 360. The problem persisted and basically was at half throttle when in WOT. Any ideas on how to fix this? I primed the bulb at the dock before I left but did not while running.
On a side note a small amount of oil/gas mixture leaks out of the shaft near the engine casing when pulling up the motor at the dock.
