Question 1)
I purchased an Evinrude 9.5HP I believe 1973 (Plate is missing). I messed with it a bit and got it running satisfactorily and proceded to the River. Here's where the trouble begins (and I should have known better). I ran across a submerged sandbar, pretty sure the prop was essentially trying to tear through a foot of sand all while sucking up the sandbar into the water pump. After this the FWD/Nuetral/Reverse selector is stuck in reverse and while the selector is stuck in reverse it is moving the propeller in reverse, but seems that the prop is not turning with proportion to the engine speed, like maybe I chewed up a gear and it is slipping.
Question 2)
Are parts for this era of Johnson/ Evinrude motors pretty well interchangeable? Can I go find a similar motor (late 60's to early 70's Johnson or Evinrude) and expect the parts to pretty much interchange? I am stuck between moving forward fixing this outboard with parts from another, or just taking it out to the South 40 and shooting at it with a rifle.
Question 2)
