what is the adjustment of the float in the evaporator box ? this motor is a 2 cycle motor
S Skeeter62 Recruit Joined Jul 30, 2015 Messages 2 Aug 2, 2015 #1 what is the adjustment of the float in the evaporator box ? this motor is a 2 cycle motor
C Chris1956 Supreme Mariner Joined Mar 25, 2004 Messages 27,148 Aug 2, 2015 #2 I presume you mean the vapor separator? If so, invert the vapor separator cover and set the float top be parallel with the cover.
