Holdemhook
- Apr 11, 2014
- 20
Hi I am currently haveing trouble keeping my 96 evinrude 115 v4 outboard running. It just keeps cutting out already rebuilt carbs set floats correctly installed all new fuel lines and vro pump and even tested on test gas tank. It seems to just fire up run a bit and cut out occasionally shaking a bit. I have the regulator out and am attempting to test it via an electrical meter and am on the right track but not sure if the results I'm getting and want to be sure this is a defective part prior to ordering, here's what I've tested and the results so far. Let me know if I'm bench testing this guy correctly and what you guys think thanks in advance.
Meter set to ohms:
Red meter lead to red wire
Black meter lead to yellow: 20 ohms
Black meter lead to yellow blue stripe: 20ohm
Black meter lead to grey: 32 ohms
Black meter lead to purple: 19.7 ohms
Black lead to red wire
Red lead to yellow wire: 0.596 ohms
Red lead to yellow blue wire: 0.580 ohms
Red lead to grey wire: 1.092 ohms
Red lead to purple: 0.604 ohms
Meter set to diode test:
Red lead to red wire
Black lead to yellow wire: 0
Black lead to yellow blue : 0
Black lead to grey: 0
Black lead to purple:0
Black lead to red wire:
Red lead to yellow: 0.465
Red lead to yellow blue wire: 0.454
Red lead to grey wire: 1.335
Red lead to purple: 1.195.
Meter set to ohms:
