when I turn the steering wheel shorts out because throttle cable moves, when I move to forward or reverse shorts out, when move cable by control box or motor end shorts, when I move anything to do with cable shorts out. motor runs just fine but when lose power shorts out power to propeller forward and reverse. has no fuses that I have found . its an electramatic control single lever with throttle tensioner . and red lever wish I think is start up idle no wires connected to it. when I move the plug wires and plate under flywheel shorts out. moter will stay running just have to wiggle or hold cable to keep it in gear or keep lights on.
