I recently bought a used Tohatsu 2003 9.8 HP 2 Stroke. I brought it home and got her running on the hose.
I hooked it up to the boat and used it 3 times and it ran pretty good (17.8 MPH with me (200lbs in a 15'4" Gheenoe).
Last night I used it in a lake and it died after 2 hours of use and would not restart so I had to paddle 1 mile to the ramp.
Today I pulled the carb apart and cleaned it well with carb cleaner and a small wire to ensure all jets were clear (the low speed jet was a bit clogged).
The Spark Plugs are totally black thick with oil/carbon gunk the texture of old axle grease, beyond fouled.
Clearly it was running rich or the gas has too much oil.
I did a cold compression test, wide open throttle with 4 pulls and both cylinders read at 130PSI.
I checked and I have spark in both plugs/wires.
I changed the plugs and gas and can not get it to start at all.
I tried a bit of carb cleaner in the carb and spark plug holes to get it to fire, no luck..
Is it possible the cylinders are so clogged up with oil/carbon it wont fire?
So I have compression, spark (visual), and gas (fresh). What else is there?
I have no idea how timing works on these motors. I guess it has CDI?
Any advise would be great.
