bigcountry11
- Aug 30, 2014
- 11
I had a loose ground to my battery while crabbing the other day. 15ft War Eagle 2005 MFS25B outboard in the Chesapeake bay. I couldn't get the bolt tight. I had to mess with the wire going to neg terminal to get the boat to start. When I ran it, it felt like I had half power. I thought it was the macks river runner I put on the skeg. It sputtered when at full power.
The oil lamp acted normal. Didn't stay on or anything. Do you think the loose connections to neg terminal could cause this? I guess after researching, this could be limp mode where it runs 2800RPM max?
Also, had other issues that need noted. Bay was rough and I had a lot of water come over the stern (since I was the only person in the boat. Probably 40gallons. That means the battery terminals got wet. So much so, I was getting slight zap when trying to tighten down the neg terminal with a leatherman since my feet was in water. (yes that much water).
