shawnMattox
- Mar 18, 2013
- 7
Hi guys I would like to start by saying I rebuilt the carb and water pump with no prior experience with help from archived threads on this forum.Thanks. Now i have the motor running good and shes peeing good but I believe I have an issue with the tiller throttle or throttle cable or both. The tiller throttle handle does not spring closed to throttle down, it stays open until I manually twist it back and I believe its the throttle cable or part of the handle assembly. I looked for a kit to purchase with the parts i mentioned and only find used parts on eBay. This problem is not letting the motor idle correctly and at first it would just rev up to a very high rpm while in neutral. This is my first motor and I need it to be in top shape when Im on the water because of my lack of experience. I thank you for your time and efforts in advance.
ShawnMattox
ShawnMattox
