Harritwo
- Oct 4, 2011
- 586
I was down south at my Dad's and went to take him out on his boat on the lake. We started the engine on muffs at the house and all was good. Went to the ramp, Backed down into the water, fired the engine off, shifted into reverse and came off the trailer. The Son went to shift in to forward to pull around to the dock so his grandpa could get in, and boat was still in reverse. Shut down engine and looked at all the linkages, everything is moving like it is supposed to. Fired the engine back off, Now boat is in neutral no matter what the shifter position is. Boat jumps into reverse regardless of what the throttle/shifter says.
After drifting away from the dock, dropped the trolling motor and motored back to the trailer. Winched onto the trailer and pulled up ramp. Went to the staging area, the shift linkage is moving all the way into the lower unit.
At this point, I pulled the lower plug of the unit and drained about 2 ounces of water, still with lots of oil, no metal shavings present. I put the plug back in and have not touched it at this point while waiting your feedback.
The engine/lower unit are still assembled. What is my next step, what am i looking for? Are parts available for this lower unit?
I have a 40 HP Nissan, Same vintage, will the lower unit bolt up? Will any parts interchange if they are still usable and new is not available?
Any help will be greatly appreciated. I hope that i am not the proud owner of a paperweight or new anchor.
George
George
