I just inherited my Dad's old VERY VERY low hour 1999 Honda BF40. The motor was used very little the past four years, and it did sit quite a while. I now have the boat and motor in Florida going through it.
I have a aggravating miss at idle. So far I have:
1. Changed Impeller
2. Changed Plugs
3. All Fluids
4. Pulled the Carbs and cleaned them thoroughly. They were gummed up a little.
Compression is great on all three cylinders. I have good spark on all three cylinders. I am using brand new fresh gas from a clean tank.
I am wondering how many turns out should the carb screws be after a cleaning and rebuild? Can someone guide me on how to sinc the carbs? This Honda 4 stroke Honda stuff is different than the 2 stroke stuff I am used to.
1. Changed Impeller
2. Changed Plugs
3. All Fluids
