TwoRivers
- Mar 10, 2010
- 344
Hello again. (I do have a Tohatsu Manual which includes this model)
Just successfully finished repairing a 10 year old leak in my rototiller transmission now onto the Nissan.
I'm certain that the leak in my outboard won't wait that long.
Spring is right around the corner here in SWPA and I need to be ready.
I have a Nissan N25C3 that I picked up in the fall and planned to tune up this winter and put into service this spring. Over the winter I noticed gear oil leaking from the prop shaft area.
I read all the threads I could find on leaking lower units.
I read where fishing line wrapped around the prop shaft area could cause seals to be damaged.
So, I took the prop off and sure enough there was fishing line around the prop shaft and back side of the thrust holder (#28 in drawing). I removed the fishing line and reinstalled the prop. The lower unit is still leaking.
It's not perceptible (to me) where the damaged seals are located?
Could somebody point me to the location of the possibly damaged seals?
Many thanks.
Rob
Many thanks.
Rob
