Re: Honda B100 Leaking Oil
Mine leaks from the breather if I tilt the motor all the way and leave it straight. If I rotate it over onto the left/tiller side then it stops. I always drop it back down when parking, which makes it a non issue.
I don't believe anything is wrong with your motor, just not designed to 'lay' on the swivel side.
Rick
