Does it matter fuel hose diameter on Honda 5 H.P?
robertjp
I need to get a new fuel hose for my 1998 Honda 5 HP kicker. Would the hose diameter matter a whole lot. I believe Honda uses a 6 mm hose but I cant find it locally. Can I just get a generic 3/8" hose assembly and use the honda fittings? Would it affect the way the motor runs any? Thanks
Sea Rider
Re: Does it matter fuel hose diameter on Honda 5 H.P?
Is 3/8" close to 6 mm ? Probably would be affected if having less interior hose diameter than original hose, will slow fuel pump fuel delivery to carb at wot.-
Happy Boating
hall832
You should be 1/4" fuel hose, make sure its the inside diameter. The SAE measurement for 6 mm is 1/4".
robertjp
The honda dealer is telling me Honda uses 5.5 mm fuel hose. Seems small, can anyone confirm? Thats less than 1/4. The Honda rep told me he thought it was 7 mm but wasnt sure.
Called Honda again and they looked it up and it is 7 mm. Now the hard part, finding it.
MattFL
Master Chief Petty Officer
That motor uses so little fuel even at wide open that 1/4 or 3/8 should be more than plenty.
hall832
You can go 5/16" fuel line or order 7 mm from a Honda Dealer.
Packard8
You can buy bulk 1/4 or 5/16 fuel hose at NAPA, etc and reuse your fittings. Just make sure it is current fuel hose rated for ethanol blend fuel.
robertjp
5/16 was too big for the fitting so I had to get 1/4 inboard hose.
