bobs.delima
- Sep 7, 2013
- 1
I have a 1999 40 hp Honda outboard. My neighbor's boy started the motor on dry land and ran it til it stopped. $450 for water impeller, then $400 replacing head gasket and then another $550 milling heads and replacing head gasket again and still water in oil. Losing confidence in the mechanic, I took to Honda dealer and he says most likely a cracked block. What to do? $1,500 in a well used motor that already blew a head gasket 7/8 years ago and cost $750. Should I "bite the bullet" and "deep 6" the thing or try to goop it with filler or something and run it till it finally croaks. New block is about $3,000. I'm so discouraged. The first mechanic won't warrant anything but parts and says i'ts my problem that I didn't have him check out the block in the first place. I'm extremely troubled, not a mechanic and need advice.
