flyhigh123
- Nov 17, 2012
- 112
I have a 2004 5hp Tohatsu Outboard 4 stroke.
When i start the motor, it runs fine, and after it while, it starts to sound as though it is not getting enough gas and slowly stalls out. If i prime and press the bulb, it comes back to life.
The engine is not getting enough fuel.
Currently my setup is fuel tank is 3/8" going to a fuel water seperator. From there the fuel comes out 2 ports, one goes to my main engine( 70hp, runs fine) and the other line goes to the kicker.
I have replaced all the fuel line in the kicker to the fuel water seperator and also changed the clamps inside the motor to t clamps( used to be a spring clamp that releases using finger and thumb).
Could it be possible the fuel pump inside the motor is not strong enough to pull fuel from 10+feet of fuel line?
I'm going to try to have the motor pull fuel from an independent fuel tank to see if its causing that.
Any other ideas?
Any other ideas?
