TheCat1212
- Feb 28, 2013
- 26
the white wire coming from the rectifier goes to a 15amp fuse. the other side of the fuse holder (also white wire) goes nowhere. it's not terminated. is this the wire that's supposed to charge the battery when running? the manual says "hot in run or start, main fuse, 15amp). if so, where does it terminate? thanks
