1st time poster here. I am in a bind after a very rocky start to my season, and there seem to be some knowledgable folks in this forum.
Any help or ideas appreciated.
Tohatsu help.
The Saga that is my sailing season continues.
3 year old Tohatsu 8 hp. Ran fine in a tank at my house pre-season. I transported it to the coast in the correct position.
Still starts easily and runs perfectly smoothly, now that the boat is in the water. Had I not opened the throttle while on the mooring, I would have never suspected a problem.
Give it a minute amount of throttle, and it responds appropriately, with a slight increase in idle. Give it any more, even very gently, and it dies.
My first thought was air starved/ bad air filter. Or, less likely, not able to draw enough fuel because of a kinked hose, fuel filter, etc. I no longer think that because:
All of the external linkage seems to operate smoothly.
My next thought is to pull the air filter, and to spray carb/choke cleaner directly into the carb, in the hope that there is some internal linkage sticking.
Anybody out there have any other thoughts?
Tohatsu help.
- I disconnected the tube running from the filter to the carb- no change.
- I briefly disconnected the fuel line between the carb and the filter, allowing it to run on what was in the fuel line for a bit- no change.
- And, if I pull the choke all the way out, it runs like it is nearly WOT. RPMs will increase slightly if I am full choke and give it some throttle.
